jeep ignition/starting major issue
  • 3
blackxj
All Things That Are Good
well the pos is at it again..the jeep is starting and the starter is staying ingadged...when i turn the key off the starter stays trying to start the jeep for about 15 to 20 seconds after its off.....when its running and i pull the starter relay the starter disingadges but when i put a new relay it it does the same thing......any ideas
haha jk man i have a cherokee that randomly starts and doesnt when ever it feels like. i think its a the switch or a loose connection in the gear shifter becuase i have to wiggle it to get it to start, i guess its not thinking its in park.
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
672
TBH, that is too many speakers for just a pair of 10" subs. The Skar 6.5s and tweeters are very efficient and can get super loud on moderate...
6
983
I purchased a set of 1" stand off rings, should still be good from door to cone as well. They won't fit without the spacers, the recoils I...
30
9K
It is the same one that Rockford Fosgate sells as well. They are identical and the NVX is cheaper as well. Even Amazon has them iirc for 199.99...
12
Is anyone familiar with, or can help with the Infinity system (with amp) fitted in 2001 Jeep Grand Cherokee? I've installed a Atoto A6 head unit...
blackxj
blackxj
eastern li
blackxj
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
