Jeep wrangler speaker placement
  • 2
2000JEEP
14
Maryland
I've seen a couple builds on the board done in 97+ wranglers. could i get away with just replacing the factory 4X6's with a better speaker to achieve a decent sound? I now have a pair of alpine coax 5 1/4's in the soundbar, but have to fade to the rear to keep the factory speakers from distorting. So sound is coming from the rear.
I have entertained building a custom box to hold a set of 5.25 components to fit in the top corners of the dash, "bottom of windshield, above the dash on both sides"
Is this overkill? will just replacing the 4x6's up front get me a decent front soundstage?
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
662
TBH, that is too many speakers for just a pair of 10" subs. The Skar 6.5s and tweeters are very efficient and can get super loud on moderate...
6
976
I purchased a set of 1" stand off rings, should still be good from door to cone as well. They won't fit without the spacers, the recoils I...
30
9K
It is the same one that Rockford Fosgate sells as well. They are identical and the NVX is cheaper as well. Even Amazon has them iirc for 199.99...
12
Is anyone familiar with, or can help with the Infinity system (with amp) fitted in 2001 Jeep Grand Cherokee? I've installed a Atoto A6 head unit...
2000JEEP
2000JEEP
Maryland
W8 a minute
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
