Northwest Region Jerome ID dB Drag & Bass Race August 22
AK,CO,ID,MT,ND,OR,SD,WY,WA
BoominAudio
The Joe Momma comp is more of a car show, so I'm sure there will be quite a few show cars. I asked some of my buddies in Boise about it and they had no clue what I was talking about. So I'm not sure if you'll see a lot of mini trucks out there.
What you buy, bro?
to start the morning off i bought a tl:D
then later on i purchased a lvl 5 motor with two 15" recones FTW!!
so we will see how a lvl 5 likes your folded horn!!
i plan on doing a direct swap test from my xxx to the lvl 5 and metering both with my tl...see which one is louder off same power and box
should be interesting plus i get to learn how to recone a sub....
i will make a vid of the direct swap test when i get the lvl 5 reconed and get my tl in!
146
378
  • Locked
681
Amp
492
BoominAudio
BoominAudio
mcbuggin
maylar
    Jun 2, 2024
    Jun 1, 2024
