JL 13W7has been in storage for 3 years. Anything I should be worried about?
STREETFIGHTER50
I bought this used, but mint with very low hours on it a couple years ago. I ended up just leaving it in storage in the original box/crate it came in from the factory. Is there anything I should do before installing it/running it again after being so long in storage?
you might want to check the ferrofluid before you use it.. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif.....also being 3 years old it wouldn't be a bad idea to to go ahead and change it before powering it up....
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
Thinking of going this year. Around August maybe? Never flown before and I know nothing about flights. Any tips on when is best time to buy...
My 1964 fender vibroverb. It’s a tube amp for guitar. It has broken many times. But it is a serviceable amp. I can fix it.
73
14K
This place used to be thriving. This place has changed much like the hobby. The brick and mortar stores are phasing out leaving no one to host...
19
4K
STREETFIGHTER50
STREETFIGHTER50
SF Bay Coastin'
Louisiana_CRX
