Jl 450/4 help
  • 1
heyhi1
nyc
I just installed the JL 450 / 4. I'm getting 12 volts to the amp is on. I had all my speaker wires disconnected and I put a voltmeter with pink noise on at three-quarter volume and I'm getting a very low reading on each Channel. I just disconnected another amp and everything was working. Either this is a bad amp or there's too many settings and I have something wrong. With the gains all the way low I'm getting a little bit of sound out of my tweeters and my wipers are not working any ideas? Can someone stick around for 10 minutes who has experience with the amplifier I'm going to be here waiting and seeing if I can figure this out thanks
Ok so I took the rears off bandpass pass and they are working only problem is that I'm testing it around 100 rms and I put the VM on and set to 20 v. 1 rear channel is at 20v and the other rear reads 10. I need help with all these options on the amp
  • Locked
Do you have any pics with user name and date or is this at a local garage sale?????????????????
Your math isn't so good. I made a mistake I'm sorry. I'm striving to be perfect like you.
5
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
479
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
535
heyhi1
heyhi1
nyc
heyhi1
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
