jl 500.1 or audiobahn 1300 hcx
  • 2
rpeterson57
15
hey im looking
at the jl 500.1 or a 1300 hcx amp
im getting an audiobahn alum12
rms of 1200
it can be wired down to 1 ohm
1300 hcx amp
1200 rms at 1 ohm
and has a remote nob to turn volume up or down
the jl amp only goes down to 1.5 ohm is this ok?
and is only a 500 rms constant from 12-14 volts
which amp will be better
rms of 1200
1300 hcx amp
1200 rms at 1 ohm
well the sub is rated 1200 rms so why would you want to only give it 500rms? Also keep in mind that Audiobahn overrates the power their subs can handle. The rms number they give is for ideal power, meaning an amp with almost no distortion. 1000rms would probably be enough if not too much.
the reason im thinking about the jl amp is that i know its real nice and clean power
ive herd that it better to go for the 500 wats of clean power then
the 1200 watts
i dont know how clean audiobahn amps are, or if they over rate there amps
so any one know any thing about either amps?
Oh come on! Why'd you have to go and tell me the price? Now I'ma start eyeballing them.
11
Please excuse this extra question .. Is there a specified patch lead or compatible bypass harness for the factory amp or would I have to create it...
4
862
rpeterson57
rpeterson57
rpeterson57
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
