jl audio 10w3v3-2 question
Yes, there will be a substantial difference however don't waste your money on a pre built box. Build one yourself or find someone to build you a custom box that will complement the JLs. Prebuilt boxes are often the wrong internal volume with a high and peaky port tune.
You'd want about 2-2.5cf tuned around 31-33hz for those JLs.
And last but not least dollar for dollar JL's are only worth the money when they are used.
The fox box is designed for my supercrew cab f150 and those subs are highly recommended for the porter enclosure, is the reason why I am considering the setup. Do you recommend any other 10" subs that would hit real hard with quality bass in a 2.2cf ported box?
Custom box contact Chris pate at mobile toys. He does lots of f150 builds. Are you planning on doing the seat lift? That opens more options. You can look at sundown sd series maybe even dc level 3s.
check out the Hertz audio site im a dealer i can get you anything you want at map pricing looking in that millie pro/energy line at that price point.
For 800, look at the sd subs and a custom box. I am a fellow f150 owner. I have 2 10 tw3s and they sound good, but I wouldn’t call it loud. Seat lift is needed to get loud because you have so many more options doe to increased mounting depth. Lmi has seat lift kits for an extra 2 inches in height
wish I knew more about car audio and what I should get for 800$ budget subs and box
For $800 you should be able to get some quality gear and/or some quantity to meet your goals... I got my subs/amps for $800... I WAS looking for a budget build tho...
Looking to trade my infinity kappa 603cf componet set and JL audio 10w3v3-4 in compact box for a nice 3 way componet set Looking for hertz or...
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
204
apeterson26
Memphis, tn
shredder2
    Jun 1, 2024
    May 31, 2024
