JL Audio 500 / 1 Amp Powering Solo-baric L7 12
  • 2
That should do it for you as long as you don't wire it up at 1 ohm final. Then again, 2 ohm power will be 1500 watts RMS and 4 ohm power would be 750 watts RMS, so I think you are covered either way.
A Link would be very helpful. Id be interested in taking a look at some gear
195
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
318
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
SilverHonda2007
SilverHonda2007
Baton Rouge, LA
gunz4me
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
