jl audio amp asking $100 plus shipping also pioneer amp $50
FOSGATE JOE
R.F team and 49er fan!!!!
1,509
CALI
Item(s) for Sale: jl audio amp
Item(s) Description/Condition: used, only used for less then a year.Yes works great
Price: $100
(List pictures in this section, 1st picture should be your username/date if you have less than 10 positive feedbacks with the i-Trader system or less than 10 references that you have sold to in the past. (These must be listed in your signature, or a link provided to a feedback thread listing these references)). Image - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
jl audio amp is 1000 watts rms modle number is mono subwoofer amplifier
400 watts RMS x 1 at 4 ohms (700 watts RMS x 1 at 2 ohms)
1,000 watts RMS at 1 ohm
Class D amplifier design
differential-balanced inputs
MOSFET switching power supply
frequency response: 10 Hz - 160 Hz
variable low-pass filter (40-300 Hz, 12 dB/octave)
variable bass boost (0-12 dB at 45 Hz)
wired remote level control included
preamp inputs and outputs
speaker-level inputs
fuse rating: 35A x 3
4-gauge power and ground leads and a 100-amp fuse recommended — wiring and hardware not included with amplifier
14-5/8"W x 2-3/16"H x 9-5/8"D
pioneer amp PWM Regulated MOSFET Power Supply
Bridgeable 1/2/3 Channel Capability
Balanced Isolator Input Circuit
Oversized Screw-Type Power/Ground Terminals
Screw-Type Speaker Terminals
RCA Inputs
Hi-Volt Input Level Control (200mV-6.5V)
Selectable Crossover: 80Hz, -12dB/oct. (LPF)
Specifications
Continuous Power (14.4V): 125Wx2 (4 ohm), 190Wx2 (2 ohm), 380Wx1 (4 ohm)
Max Power (14.4V): 250Wx2 (4 ohm), 760Wx1 (4 ohm)
Frequency Response: 10Hz - 50kHz (0,-1dB)
Total Harmonic Distortion: 0.008% (1kHz, 4W)
Signal-to-Noise Ratio: 100dB (IHF-A)
Dimensions: 11" x 2-5/16" x 12-3/4"
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
The 750 will give you better control at higher volumes as you won't be reaching clipping as soon..
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
FOSGATE JOE
FOSGATE JOE
CALI
dude661
