Jl Jx500/d keeps going into protect
  • 4
Erikg223
CarAudio.com Newbie
15
CT
hey So I'm fairly new to car audio still learning each day I have a jl jx 500 hooked up to my two 10 inch Rockford Fosgate subs and I keep coming to the problem with the amp turning off while my system is on the highest volume. I also got a 10 ich chuchero box with two 10inch mids and two supper tweeters powered by a Rockville rxa-f1. I've been troubleshooting but have had no luck one thing I did find out was when I disconnect the RCA's from the other amp it doesn't turn off at all but once both are connected the JL just goes in to protect but once I turn it down a bit it goes back to normal. thanks in advance for the advice.
Hve you meassured the power to it? The rca Cables are just signals from the radio to the amp and wont turn amps on or off, check if the ground is solid and that its grounded to bare metal
No I haven't measured the power to it and today I cleaned up the ground making sure it was bare metal so I don't think its that.
This usually means that the amp is not getting enough power to play at high volume. Are you sure the cables are the correct size? You should also see if all the connections are solid in the ground and power.
I was thinking that it could be the power but the things is that it just started and I've had the amp for about 4 months
Since nobody else is going to ask
Which RF subs?
Are they single or dual VC
If they are dual how do you have them wired?
its two Rockford fosgate RFZ 3410 its a single voice coil and I got the box for free from a family friend and he had it wired just both speakers going directly to the cup terminal. so both speakers meet at the cup terminal and the wires do not connect to each other
This means a lack of power. When both RCAs are plugged in, both amps are playing. When power drops, the bigger amp will shut down. You should have a 4 AWG cable and at least an 80 amp fuse.
I currently have 4 gauge wire ruing to a distribution block that has two 8 gauge powering the amps but I've recently ordered 4 gauge so it 4 gauge all around and I have a 100 amp fuse by the battery
I thought maybe you were running DVC's and over loading the amp but your running at 2ohms which is what the amp can handle.
A 4 gauge run on that amp should be suppling the power it needs
Maybe there is something wrong with the amp internally.
It should still be under warranty
I bought the amo used so I do not know how old it is but it’s strange because it’s been working fine and just started Turing off I do think it could be something internal because I’ve checked everything else
Hold up a minute. If it stayed on when hooked up to the remote wire on the head unit, that's a problem. It means your head unit is staying...
6
it comes tomorrow and i cant wait. Thanks for spotting that amp and recommending it!
19
4K
Now you're annoying me because you are attacking me personally without addressing anything I've said. Show me a single post I've made that's...
20
4K
I'm thinking that my Pioneer DEH-P880PRS does, for a little while. Not for months though. if you can find them, they are not cheap. Just pulled my...
11
Sounds like a bad ground or wiring problem on the 12v+ side.
13
Erikg223
CarAudio.com Newbie
Erikg223
CT
Erikg223
