JVC Headunit issues
  • 2
tgclark84
I have a jvc headunit, not sure what the model is right now but when ever I put a cd in the radio turns off and on again and again. If I hit source and change it to the radio then it stays on. It will eject the cd but just cycles on and off. Next when I have the radio volume up around 28 it does the same thing, cycles on and off. When I plug my ipod up to the head unit it only allows the volume up to about 20 and then starts to cycle on and off. If I turn the volume down while on the radio or usb the unit works fine. Has anyone ever had this type of problem?
Shutting off at a volume level is usually a short in speaker wiring or internal damage or grounding . Cycling on/off when you newer a cd is strange.
Check your ground, take it to car metal.
Translation: Hi Get someone here to do the update, this headunit with a flash usb downloads the files I need before update and stored in the usb...
33
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
9
tgclark84
tgclark84
charlotte, nc
keep_hope_alive
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
