jvc headunit problem
  • 1
Hey guys, i have a jvc-kdc 650 headunit. I never really played it loud until i recently got subwoofers. My problem is that at any volume and wether its in USB or AUX playin music it skips..skips and in a split second the music will stop n continue going. It sounds like an old cdplayer. I turned subs off, i disconnected them and still does it. Took it back out. Added a new ground, checked power and speaker wires and i thought i had it but 45 mins later it started again. Then it didnt do it for the whole ride home(another 45) itll do it randomly, maybe 6 or 7 times a song and thats every song and then stop. There brand new speakers (kicker 5.25) and i made sure there all in phase. I put these in last year tho but this just started once i started listeing to it loud. This is in a 96 jeep cherokee and i have a 160amp alt. Worse comes to worse il switch headunits from my car to this.
Google do it translate what ever i do
4
364
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
9
johnMZ24
johnMZ24
schuylkill county pa
johnMZ24
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
