JVC KD-G125 headunit
  • 2
Tiffybass20
An affordable CD receiver with 50W x 4 high power output. This receiver delivers high-quality sound from CDs, CD-Rs, and CD-RWs, with a 1-bit DAC, cEQ, and carefully selected components.
# Power Output: 50W x 4 Max.
# 1-bit DAC
# CD/CD-R/CD-RW Compatible
# cEQ
# Rear/Subwoofer Output Terminals
# Subwoofer Level Control
# Rotary Encoder Multi-Control
CD Section
# Direct Track Access (1-12)
# Random/Repeat Play
Tuner Section
# HS-II Tuner
# 18 FM and 6 AM Presets
# SSM (for FM)
# Seek (Up/Down)
# AFNS/PNC
# Stereo/Mono Switch (for FM)
# Auto Antenna
Amplifier Section
# Balance/Fader Control
# Volume Attenuator
# Super Bass Control
# Max. Amp Gain Switcher
Display Section
# White LED Backlight
# Power Switch Standby Illumination
General Section
# Detachable Control Panel with Carrying Case
# COMPU PLAY
# Power-Off Mode Eject
# Preferred Setting Mode
$100 ONO
Shipping at your own expense!!!
Translation: Hi Get someone here to do the update, this headunit with a flash usb downloads the files I need before update and stored in the usb...
67
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
9
Tiffybass20
Tiffybass20
Australia, NSW
Bettr n' Revrse
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
