JVC Navigation Owners
  • 1
TexasThump
30
Enid, OK
Got a question. I had my JVC KW-NT800HDT installed in my 2008 Sierra and all of the settings/Navigation/DVD options worked while the vehicle was in motion, however now that I have my new SUV, I installed it without the VSS Wire and the Brake Wire, so it's running off of the GPS Sensor and I cannot select anything in Navigation, change my audio settings or play DVD's while the truck is in motion.
My question is, is the Brake Wire triggered by a ground or a positive signal? Do I need to connect the VSS Wire? I believe I need to ground the Brake Lead Wire and it's not necessary to hook up the VSS Wire. My VSS Wire is behind the dash gauge cluster so it's a pita to get to.
Also, certain audio settings keep getting reset; the active crossover keeps reverting from having it active and crossed over at 80Hz back to "Through" as in Pass Through. I haven't installed the update on the unit yet. I didn't have this problem with my previous 800HDT. This is a brand new unit as I had it replaced after totaling my Sierra.
Google do it translate what ever i do
397
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
TexasThump
TexasThump
Enid, OK
TexasThump
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
