Kenwood 6x8 vs JBL 6.5"??
  • 2
RBass22
CarAudio.com Newbie
Hi all, I'm new to the forum and haven't done much with car audio since 2008'ish. I'm planning a very simple system for an old '98 F-150 extended cab. Going to be running an aftermarket HU, 2 sets of 6x8's (Kenwood KFC-C681 - 81w RMS - 4 ohms) or 6.5's (JBL GX628 - 60w RMS - 2 ohms) in front & rear doors, and 2 JBL 12's in ported enclosure. Will be running mids/highs off an amp with 60-100w rms per channel. My question - is it worth it in this case to build/buy adapter plates to run the 6.5's or would you just go with the 6x8's? They both sound decent (for the price).
Hey mate,
With a similar size speaker, not much difference as the cone areas are identical. Only difference is that one would have a more efficient tweeter to the other. Secondly, if you sound deaden the doors then that will provide you with a better detailed midbass, not low bass. Using your kenwood amplifier, sound deaden them doors and give what you have a go, before you go out and spend more cash on new speakers which is not worth the improvement unless you want to add a dedicated subwoofer and another amplifier. With car audio, you may be fiddling around changing speakers, subwoofers until you are satisfied for a while then its of again! That is what I do mate, but you maybe more content then me! :)
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
473
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
4
740
RBass22
CarAudio.com Newbie
RBass22
Orlando, FL
DRBOOM
Doxquzme
    May 22, 2024
1aespinoza
    May 22, 2024
