kenwood ddx5707s won't boot up
  • 2
How long did you let it sit when you disconnected the power
You disconnected the red and the yellow wire right (it's a lot easier to just disconnect the battery)
If it's the screen that's the problem it could be booting up and you just can't see it
I disconnected the battery. I then let it sit for about 10 minutes. After I hooked back up, the unit did the same thing. It has the button lights illuminated but the screen remains black.
Thought I would update this thread… Couldn’t login over the weekend for some reason. Finally got the Kenwood installed last Friday… Had a little...
32
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
391
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
938
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
4
688
dustin.nelson
CarAudio.com Newbie
dustin.nelson
AZ
dustin.nelson
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
