Kenwood KAC-X40
  • 6
Joseph7195
Walkin Tall
Kenwood KAC-X40 Class A/B 4-Channel Amplifier
Good Condition, minor scratches. 9/10 aesthetically, 10/10 functionality.
Specs:
4-Channel Amplifier
Peak Power: 800 watts
Power Handling:
70 watts RMS x 4 @ 4 ohms
100 watts RMS x 4 @ 2 ohms
200 watts RMS x 2 @ 4 ohms (bridged)
2 ohms Load Capability
Bass Boost Frequency: 40 Hz - 100 Hz
Frequency Response: 5 Hz - 70 kHz
CEA-2006 Compliment
Line Output Terminals for Extension
Cast Aluminum Heat Sink
Power MOS-FET Switching Power Supply
Stereo,Mono Operation
Dimensions: 11-1/4" L x 14-15/16" W x 2-9/16" H
$120.00 Shipped OBO
Shipping and Miscellaneous Item Information: Shipping will be USPS and insured with tracking, and is included in the asking price unless other arrangements are made with buyer.
This is a video of all 4 channels working and also my sub amp, which is for sale, and it's funtionality too.
how does this compare to the kenwood KAC 8405? its almost the same specs
4-Channel Performance Series Class AB Car Amplifier
RMS Power Rating:
4 ohms: 60 watts x 4 chan.
2 ohms: 90 watts x 4 chan.
Bridged, 4 ohms: 180 watts x 2 chan.
Max power output: 720 Watts
MOSFET power supply
LED power indicators
4/3/2 channel operation
Speaker-level inputs
Input sensitivity control
Bass boost switch
Short circuit, DC offset, overload, and thermal protection circuitry
Signal sensing turn-on
Cast aluminum heat sink design
Built-in cooling fan
Gold-plated RCA level inputs
Gold-plated screw terminals
Single side exposure of terminals for multi-installation
Variable high-pass filter (50-200 Hz, 12 dB/octave)
Variable low-pass filter (50-200 Hz, 12 dB/octave)
CEA-2006 compliant amplifier
Frequency response: 50-200 Hz
Dimensions: 11"L x 2-5/16"H x 9-3/8"D
8-gauge power and ground leads recommended. Contact us for information regarding a discount on a select amplifier kit when purchased together.
1-year Sonic Electronix warranty
im trying to see if theres enough of a difference to switch out and buy this one?? any inputs?
There's a couple key differences between the two, which is one of the reason's they don't sell one like mine anymore. First, the X40 is what's considered a "digital" amp which the 8405 is not. The X40 is very very efficient and has a max THD of .5% where as most other amps will say "min THD". this means as you turn it up, distortion is going up too, which is a no no at high volumes. Plus the added power would make it easier to power components and easier on your electrical.
I have mine on a set of Boston Acoustics speakers rated at 60 watts and I don't have the amp set up very high, so it gives me plenty of leadway powering my speakers.
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
Bridging the amplifier Mono(LPF)on that sub will work just fine @4ohms
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
630
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
874
Joseph7195
Walkin Tall
Joseph7195
Saltillo, Mississippi, United States
Joseph7195
