Kenwood KDC-BT752HD, any good??
  • 3
I'm pretty new to speaker-ology, so can you explain rms?
RMS stands for Root-Mean-Square. It is a method of measuring the average voltage value of alternating current from the source
in noob terms, RMS means what wattage you will actually see from the headunit/amp output and RMS on a sub means what it can safely take daily with out exceeding its mechanical limits.
RMS stands for Root-Mean-Square. It is a method of measuring the average voltage value of alternating current from the sourcein noob terms, RMS means what wattage you will actually see from the headunit/amp output and RMS on a sub means what it can safely take daily with out exceeding its mechanical limits.
Well I plan on getting an amp in the future, so I'm not sure if the rms really makes a difference?
you have alot to learn sir //content.invisioncic.com/y282845/emoticons/graduate.gif.d982460be9f153bb54e5d4cb744f6ae8.gif
I currently have this exact deck in my wife's vehicle running both JBL Power and GTO coax in the doors and a sub off a seperate amp. Great deck with plently of features and great flexablity, good value there I say go for it....
I would call Kenwood Tech support. Im sure they will try to help you
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
655
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
4
897
Jlandry287
Jlandry287
Lake Charles, LA
DARKHART
Decebal
    Jun 10, 2024
