Kenwood kiv bt900 help please
  • 1
thaglyde
Hey fellas. Im new to kenwood and I took time to read the manual (first time in 5 years) but I cant figure out how to get a set of speakers to run off of the amp while another set of speakers are running off of the radio. I did see an internal amp set up and I have not gotten sound by toggling that option. On my Alpine there was a setting but im not sure if it’s the same on the kenwood. Also, Im only running tweets with not crossover to the radio and I wanted to know what a safe crossover setting should be to prevent blowing the tweets on the front channel. If needed, they are a set of hertz bt16 tweets. The specs are:
Minimum Frequency Response [Hz]: 3000
Maximum Frequency Response [Hz]: 21000
Sensitivity (Efficiency) [dB]: 93
Peak Power Handling [Watts]: 80
RMS Power Handling [Watts]: 80
Impedance (per voice coil) [Ohm]: 4
Any suggestions would be greatly appreciated.
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
654
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
4
894
thaglyde
thaglyde
Richmond, VA
thaglyde
Decebal
    Jun 10, 2024
