Kicker 2010 C15 With DX 250.1 Amp?
  • 2
HitCast
Nevada
Hey guys, I'm new to this forum and I was hoping to find some help regarding my upcoming system, I have been around cars my whole life but this is my first time really getting into the audio aspect of it all. In my 1989 S15 Jimmy I have a 2Din 7" Kenwood touchscreen and 6 150w 6" pioneer speakers. I just ordered on amazon a Kicker C15 in a ported box and a DX 250.1 that were together for 210$. I have a little bit more in my budget but I was mainly wondering if the amp is underpowered or anything else I need to know. And if any of you can guess how it'll sound it'll be much appreciated. Here's the specs for the Sub, Box, and Amp, thanks.
Subwoofer Box Features:
Single 15" Vented Sub Box
Mounting Depth: 21-1/4"
Air Space: 2.30 Cubic Feet
Vented Enclosure
Dimensions: Width 20-1/2" x Height 17-3/4" x Depth 22-1/4"
Vented design allows for maximum output
Constructed with High Quality MDF
High Quality Binding Terminal Cup (Accepts Banana Terminal Plugs OR Bare Wire 'up to 10GA')
High Quality Gray Carpet
This item is Brand New
Kicker C15 Specifications:
Kicker C15 15" Subwoofer Single 4 Ohm 250 Watts (10C15-4)
Power Handling:
Peak Power: 500 Watts
RMS Power: 250 Watts
Impedance: Single 4 Ohm
Sensitivity: 90.3
Frequency Response: 25-500 Hz
Mounting Depth: 7-7/16"
Mounting Cutout: 13-11/16"
Amp Specifications:
• Kicker certified power output:
140 watts x 1 (@ 14.4V, 4Ω, ≤1% THD+N)
250 watts x 1 (@ 14.4V, 2Ω, ≤1% THD+N)
• Frequency response: 20 to 200 Hz (±1 dB)
• Input sensitivity:
Low level: 125 mV to 5V
High level: 250 mV to 10V
• Signal-to-noise ratio: >95 dB (A-weighted at rated power output)
• Crossover (switchable):
LO (fixed): 80 Hz, -24 dB/octave low-pass
• Fixed bass boost (switchable): 12 dB @ 40 Hz
• Dimensions (L x W x H): 10-1/4" x 8-5/16" x 2-1/4"
The amp is definitely underpowering: 4 ohm rating being 140wrms vs the sub being rated at 250w.(It's a 4ohm sub). Also the box is too small. Kicker recommends a 3-4 cuft vented enlosure.
Enclosure Compatibility
Enclosure Versatility: The Kicker Comp subwoofer is versatile, performing in vented or sealed enclosures, and in free-air applications as well.
Sealed Enclosure Applications: A sealed enclosure design gives the smoothest response with increased energy at the lowest frequency between 20 to 30 Hz.
Compact (minimum enclosure volume): 2.25 cu/ft
SQ (maximum enclosure volume): 5.0 cu/ft
Recommended Vented Box Volume: A vented enclosure design is the choice for loud, high-performance bass for SPL contests.
Compact: 3.0 cu/ft with a 2.5" x 15.5" slot port opening that is 17.0" in depth
SQ: 4.0 cu/ft with a 3.0" x 15.5" slot port opening that is 16.25" in depth
Thank you I appreciate the reply! Is there an amp that you can recommend? And I have another box that I can use that is quite a bit bigger than this one.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
929
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
HitCast
HitCast
Nevada
HitCast
Decebal
    Jun 10, 2024
