Kicker Comp 12"s?
  • 1
Emmick
11
Stockton
i need help setting up a 93 suburban. right now i am running an eclipse deck, a pair of eclipse 4x6, the stock 5 1/4 in the doors, and a pair of eclipse 4x10's. to take care of the low end, i have 2 kicker comp 12's. i am running a piece of crap 140 watt 2 channel amp for the subs. I want a new set up for the low end, amp and 5 1/4. for the low end, i am also considering the JL H.O. Wedge, housing two 15"s any sugestions?
[ 12-18-2001: Message edited by: Emmick ]
Question…Will a kicker solo x 15 in a custom 5 cu ft enclosure hit in a ford edge with a kxa1800/1? I also have a UC31 with an AGM battery.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
534
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
Emmick
Emmick
Stockton
Emmick
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
