kicker cxa400i stuck in protection
  • 1
nolivesmatter
CarAudio.com Newbie
i recently had this amp hooked up to a ac to dc power supply and i sent to much voltage to it about 19.5 volts maybe higher.the red light came on and wont turn off now until i turn the power off.there is no fuse on this amp.did i destroy this amp or is there a way to fix it?i checked and changed all my wiring so i know its not that .i tried lowering the voltage down until the red light was barely glowing.none of these worked.i also looked under the hood for any blown out caps and they all seem fine.any ideas would be greatly appreciated.if not im going to turn it into an ashtray
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
610
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
nolivesmatter
CarAudio.com Newbie
nolivesmatter
Philadelphia
nolivesmatter
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
