Kicker Hideaway --> No Sound at all
  • 2
Jay1987
Hello Guys,
Im also new on this Forum.
My Name is Jan, 29 years old from Germany but currently living in Australia.
Ive searched the Forum for following Troubleshooting but didnt found something similar.
I bought a Mitsubishi Challenger 2001 over here for traveling the Country and wanted some more Sound in my car. Ive done a lot of HU and SUB installations in Germany before, so im not a total newbie ?
What i have done so far:
Changed the Factory HU to a Pioneer DEH-X3850 which worked fine (good Sound on Front and Rear speaker)
I also bought the Kicker Hideaway because i dont have that much Space in my car to Build a big System (was on sale aswell)
Wiring:
Power: from the passenger Seat where the Sub is located through the Firewall to the battery 12V+ ✔️
Ground: underneath the passenger Seat (fiter some bolts and connected it to baremettal) ✔️
Remote: Connected it to the Blue / white wire from my HU (Antenne i think)
Tried different once aswell without success.
Audio:
Here i tried nearly every possibilities:
Connected the kicker Audio wires to the Front speaker wires of my HU ✖️ didnt work
Connected the kicker Audio wires to the rear speaker wires of my HU ✖️ didnt work
Bought a 2 Channel High to Low Converter
The Build in Kicker harness just got wires as Input and no RCA.
So i connectes the Converter to the wires and used the RCA Outputs of my HU ✖️ Didnt work
The small LED on the Hideaway is glowig Blue but i dont get any sound at all.
The hideaway Settings are on 12V+ and the Input Level was changed from high (Using Front and Rear speaker wires) to Low (Using the 2 Channel Converter via RCA)
Any suggestions?
Thanks in Advance
Depending on the Connection but:
HU was Set to RCA while rca connected and Rear / SUB while wire connectes.
SUB:
12V+
Input Level: low (Connection via rca) high (via Wires)
Phase: 0^
X-over, gain, Bassboost around 3/4
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
884
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
Jay1987
Jay1987
Germany
Jay1987
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
