Kicker IX1000.1 vs Audiopipe 1500d @ 2ohms
Donks
CO, Ohio
Hey guys i have 4 type r 12s dual 4 ohms which is a 2 ohm load. Currently I have the apcl 1500d wired at 2 ohms and its amazing, my friend is trying to trade me a Kicker 11IX1000.1 which also does 1000w @ 2ohm. Should i keep my ap or trade for kicker?
If it's amazing, I wouldn't mess with it. If you do it, make sure you guys swap amps first and see if it really fits the other.
I ended up trading for the kicker amp an hour ago, it sounds great and even better and louder than the AP, and less voltage drops
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
885
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
Donks
Donks
CO, Ohio
Donks
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
