Kicker KX700.5
  • 4
85cutty
Im thinking about gettin this amp to power, my 3.5 concept CFN-350, JBL P-9632, and My 12" type R 1241D, do you guys think this would be enough power for the type r... heres it specifications
Amplifier Type: Multi-Channel
RMS Power: 40W x 4 + 200W x 1
Bridged RMS Power: 150W x 2 + 400W x 1
THD at Rated RMS Power: 0.085%
Speaker Level Inputs: Yes
Preamp Outputs: Yes
Built-In Crossovers: HP/LP
Bass Boost: 0 - 18 dB
Frequency Response: 20-20,000 Hz
Channel Separation: n/a
Signal to Noise Ratio: >95 dB
Fuse Rating: 3 x 30 amps
Leave your Feed Back
thanks
im thinking about buyin this amp for all my ****.... i was wanting to get another type R but summer is coming up and i would have to buy 2 amps and another sub and i want to get rims this summer too.... sooo im thinking about gettin this amp its seems like it would be perfect for what i got right now....
Originally posted by 85cutty um its gonna cost me like 500 canadian... and you can wire a single 4ohm DVC to 2ohms...
how can you wire it to 2 ohms....impossible w/out another sub or something to give the amp 4 ohms of resistance.....not seeing where you're getting that from
Originally posted by Woodmister The type R 1241D = single 4ohm, which can only be wired into 4ohms and 4ohms only. Now you can try to trade or return it for a DVC model, but thats the only way. If you would like another, cheaper amp, we might be able to help ya out...
read the post, it is a DVC!!!!!
912
85cutty
85cutty
Vancouver
Wonderbread
