Kicker S12L7 Ring/Square
  • 5
Hey guys.
I'm having a hard time finding a Kicker S12L7 ring/square. Its the part that goes on after you screw all the screws in to hide them.
It's the part that says Kicker in each corner of the attatched pic.
Any ideas where I can get one? Mine is missing and its doesnt look as good without it compared to the brand new enclosure it's in. Also, I only need one...but if I can only get them in twos, that's fine.
I was looking at the grilles, but no way I went to spend 30$+ for a pair of grilles when I just need the ring.
Thanks in advance.
EDIT: Can someone tell me the proper name of that part so I may try to find a one?
20051
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
940
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
HighlanderAudio
HighlanderAudio
Tulare County, CA
Bobbytwonames
