kicker solobaric s10L7 voicecoil repair
  • 3
Are you referring to a recone or is the voice coil actually damaged? Either way you're probably better off getting a new woofer.
Its the voicecoils. had them replaced twice already until i realised its the faulty amp. had that fixed as well. anyway the L7's are pretty expensive here hence the repair option but i would like to fix it myself this time around if possible. otherwise i will consider another woofer.
What are the coils doing? Are you sure your amp is damaging them? Or do you have your gains set too high and are clipping the hell out your subs and they are getting damaged?
the coils got too hot and fused.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
617
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
ffkk
ffkk
PTA, RSA
ffkk
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
