Kicker SX 600.2
  • 1
nate56
colorado
[1. Product:
Kicker SX 600.2
2. Specs:
138 watts RMS x 2 at 4 ohms (275 watts RMS x 2 at 2 ohms)
550 watts RMS x 1 bridged at 4 ohms
lockable settings (with keypad security code)
variable high-pass filter (10 Hz - 16 kHz) with adjustable slope (0-36 dB/octave, 6 dB increments)
variable low-pass filter (30 Hz - 20 kHz) with adjustable slope (0-36 dB/octave, 6 dB increments)
high-pass filter can be used as a subsonic filter below 20 Hz
SORT 4-way protection circuitry (short circuit, over voltage, reverse polarity and thermal)
Digital KickEQ single band parametric equalizer with variable center frequency and variable Q
Kompressor expansion/compression circuitry with four settings: Off, Contour, Attack, and Redline
4 memory banks store intricate EQ cut/boost, low-pass crossover, phase, bass boost, sub-sonic filter, and compression settings
Sick Bay technology for real-time diagnostics and troubleshooting (includes pink noise generator)
preamp outputs
UltraMatch gain control for optimal input level matching
cooling fan
removable endcaps
requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
22-3/8"W x 2-9/16"H x 9-15/16"D (with endcaps) 20-1/16"W x 2-7/16"H x 9-15/16"D (without endcaps)
3. Description/Condition:
7-8/10 looks
10/10 working just roved from vehicle. Used to power a SA-8v3
4. Price: :
200 OBO
Item Pictures: View attachment 26555169View attachment 26555168
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
890
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
nate56
nate56
colorado
nate56
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
