Kicker SX900.4 and SXRC
  • 1
SoCalBean420
Cali
View Listing
Nos equipment. Back when kicker was producing gear that was ahead of it's time.
  • Kicker SX900.4 4-Channel Amplifier with DSP
  • 32-Bit User-Programmable Digital Signal Processing
  • RMS Power Rating:
    107 watts x 4 channels @ 4 Ohms
  • 213 watts x 4 channels @ 2 Ohms
  • 425 watts x 2 channels @ 4 Ohms Bridged
[*]UltraMatch Gain Structure, single-band parametric KickEQ (Variable Gain, Boost, and Q), and crossovers ( Variable High and Low-Pass Filters )
[*]SAMS (Stereo And Mono Simultaneously)
[*]ISIS (Indicate Status & Input Settings) Interface
[*]BLAST Port (Bass Level And Signal Transfer) Provides Remote Bass Level Control and control signal transfer between multiple SX amplifiers
[*]Kompressor
[*]Adjustable Phase Control: 0 - 180°
[*]EndKaps: Cast aluminum, custom, removable covers to protect and hide all your wiring connections to the amplifier
[*]SickBay and On Board Diagnostics
[*]Frequency Response: 20 Hz - 200 kHz
[*]Variable Input Sensitivity: 1V / 2V / 4V / 8V / 16V
[*]Signal-to-Noise Ratio: >100 dB
[*]MOSFET Power Supply
[*]RCA Outputs: 1 Pair
[*]Remote Gain Control
[*]Fan Cooling
[*]Dimensions (With Endcaps): 25-3/4" L x 10" W x 2-1/2" H
[*]Authorized Internet Dealer
[*]2-year Manufacturer's warranty
Hide Full Description
Features & Specs
Power Specifications - Full Range Channels
RMS Power @ 4 ohms107 watts x 4 channels
RMS Power @ 2 ohms213 watts x 4 channels
RMS Power @ 1 ohmNot Stable
Bridged RMS Power425 watts x 2 channels
Power Specifications - Subwoofer Channel
RMS Power @ 4 ohms
RMS Power @ 2 ohms
RMS Power @ 1 ohm
Peak Power @ 4 ohms
Peak Power @ 2 ohms
Peak Power @ 1 ohm
Bridged Peak/Max Power
Peak Power @ 4 ohm
Peak Power @ 2 ohms
Peak Power @ 1 ohm
Amplifier Specifications
Amplifier Series
Amplifier Class
Number of Channels4
Total Peak Power Output
Total RMS Power Output852 watts
Maximum Input Gauge Size
Minimum Impedance Unbridged2 ohms
Minimum Impedance Bridged4 ohms
THD at Rated RMS Power0.02%
Speaker Level InputsNo
Preamp Outputs1 Pair
Built-in CrossoverLow-Pass (LP)
High-Pass (HP)
High-Pass Crossover Frequency10 - 16000 Hz
Low-Pass Crossover Frequency30 - 20000 Hz
Signal-to-Noise Ratio>100 dB
Bass Boost-18 -- +18 dB
Bass/Gain RemoteYes
Fan CooledYes
Fuse Rating40A x 3
SXRC..
  •  Control for SX Amplifier Network
  • Blue-Background ISIS soft-touch keypad
  • ISIS VFD Display
  • 10 User-assignable groups controlling multiple amps
  • Single-amp control available
  • Digital remote bass level with attenuation
  • Four global "Memories" storage
  • SickBay function displays amplifiers vital signs
  • Provides date and time
  • Metal-mounting can an ttrim ring included
  • Authorized Internet Dealer
  • 2-year Manufaturer's warranty
553
SoCalBean420
SoCalBean420
Cali
SoCalBean420
    May 12, 2024
Brendon Jenness
    May 11, 2024
