SOLD Kicker ZR360
xxxbasshead
Kicker Zr360
does not have the kicker badge or a crossover module included
Details:
* stereo or bridged mono output
* Tri-way capable (Tri-Way crossover required)
* frequency response 10-28,000 Hz
* 90 watts x 2 at 4 ohms
* 360 watts x 1 in bridged mode at 4 ohms (underrated and will run at 2 ohms bridged, not sure about 1 ohm tho)
* 180 watts x 2 at 2 ohms
* MOSFET power supply
* module docking port with 2-way active crossover (80 Hz low-pass, 100 Hz high-pass, 12 dB/octave)
* discrete output transistors
* silent turn-on/off circuitry
* removable endcaps and logo plate
* 18-3/8"W x 3"H x 10-1/16"D
10/10 mech and id say 7/10 cosmetic
175+ship OBO
Will add cash for a good trade.
actual shipping cost thru carrier of buyers choice
Mine will take 1 ohm for short periods. They overheat quickly at 1 ohm, and eventually the smoke will come out the box... Should be fine for comps/temp stuff but not for daily. I run mine at 4 ohm on a TC-1000 and it is great, these are clean sounding and are underrated for power. They're great with mids/highs too.
they are 1 ohm stereo capable and rated for it
they are also 2 ohm bridge rated as well....
http://www.kicker.com/sites/default/files/ZRAmpsMan.pdf
they put out the most power 1 ohm stereo / 2 ohm bridged FYI...
brother is running 4 of his 8 ZR amps at 1 ohm stereo... powering D2 subs with them...
most I have ever ran them at was 1.33 bridged iirc but I do not recommend it since they are vintage amps..
we used to use em to run the 6" F series ( free-air ) kicker midbass with the reso series comps.
bump, bought a SWX crossover module should be arriving by friday //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif so that will also be included now.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
703
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
xxxbasshead
xxxbasshead
lake forst , ca
xxxbasshead
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
