Kicker ZX 750.1 blinking protection! HELLPPP
  • 6
chasestrickland
WTF my zx 750.1 took a dump for no reason. When I hook it up and turn the car on it just goes in to like a pulsating protection mode. Im thinking that it has to be an internal problem because I can unhook that amp and hook up my Audiobahn 750 2 channel amp and it works perfect. Anyone have any ideas on what it might be???
you might have it wired to a super low load maybe 0.5 ohms
try simply wiring 1 sub run it free air if you have to and see if it will play
What kind of subs are you pushing? Are they dual 4ohm or dual 2ohm? What size cable are you using? Also what kind of car is it in? Were is your ground cable grounded on?
Its just a single 15 inch CVR dual voice coil 2 ohm , in a Chevy Blazer. And its grounded to a seat bolt for one of the rear seats. I just dont understand because my other amp runs it fine. But it is a 2 channel. How could I increase the load?? And the gain is all the way down
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
925
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
chasestrickland
chasestrickland
Vero Beach, FL
johnbubby5
Decebal
    Jun 10, 2024
