Kicker zx1500.1
  • 1
select127
Florida
Kicker ZX1500.1
Amp in perfect condition, minor signs of wear. I believe its the 09 model right b4 the newest one. Performs 100%
$280 shipped
Trade for Sundown 100.4
Price is SHIPPED
ITEM SPECS:
ZX Series Class D Monoblock Car Amplifier
RMS power Rating:
4 ohms: 750 watts x 1 chan.
2 ohms: 1500 watts x 1 chan.
Max power output approximately 4500 watts x 1 chan.
MOSFET power supply
Wired remote bass level control included
LED power and protection indicators
Tuned Bass EQ (0-18 dB bass boost at 40 Hz)
Balanced differential inputs make KICKER ZX Amplifiers compatible with any factory radios
Eliminates unwanted noise in a system
Boost, gain, and crossover frequencies are top-mounted for easy access, and a handy protection indicator featuring a new flashing yellow low-voltage light enhances the end panel
Bridgeable operation
Speaker-level inputs compatible (switchable) through rca connection, Kicker 09ZISL required and sold separately
Preamp rca outputs
Automatic turn on modes: remote, DC offset, or signal sense
Thermal, voltage, and short circuit protection circuitry
Variable low-pass filter (50-200 Hz, 24 dB/octave)
Subsonic Filter (24 dB at 25 Hz)
CEA-2006 compliant amplifier
Frequency response: 25-200 Hz
Dimensions: 20"L x 9-5/8"W x 2-1/8"H
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
874
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
select127
select127
Florida
select127
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
