Kicker ZX400.1
how bout a 2 ohm sub? Anyways i have zx300.1 powering a 10" CVR at 2 ohms and its a great amp... overheated it a few times and had it running at twice the correct output voltage for my RCAs and its still workin great (had gain up all the way and output was 52v when it should have been at 24.5. I did blow the sub tho.
789
Bdawg15
Bdawg15
Atlanta, GA
jdeaton
    May 31, 2024
    May 24, 2024
