Kicker ZX500.1
  • 2
kfx450r
Kicker ZX500.1 Amp, (500rms @ 2 ohm)
Great condition as seen in pics, will do close to 600 according to birth sheets all @ 2 ohm. It is however missing the terminal screws (sunken hex head ones) for the power/ground. I ended up buying some screws from Lowes and they fit perfectly, could be cut shorter for more aesthetic appeal but works fine.
125$ Shipped
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
897
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
kfx450r
kfx450r
Hammond, Louisiana
kfx450r
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
