Kicker zx700.5
  • 2
nutxo
tacoma
Item(s) for Sale: Kicker zx700.5
Item(s) Description/Condition: Its in really good shape aside from scratches on the back and a few very small scratches on the front. Id give it a solid 8/10 cosmetically. Includes bass knob and cord.
5-Channel Amplifier with Class D 5th Channel for Subwoofer(s)
RMS Power Rating:
4 ohms: 70 watts x 4 chan. + 210 watts x 1 Class D Sub channel
2 ohms: 85 watts x 4 chan. + 420 watts x 1 Class D Sub channel
4 ohms (bridged): 130 watts x 2 chan. + 420 watts x 1 chan. (2 ohms sub channel, 210 watts @ 4 ohms)
Bass Boost Remote Control: 0 - 18dB at 40Hz
CEA-2006 Compliant
24dB per octave Crossover:
Active at 50Hz - 200Hz
High Pass, Low Pass, or Full-Pass selectable
4 gauge power/ground leads
Dimensions: 20"L x 9 5/8"W x 2 1/8"H
Price: 185 shipped
Shipping and Miscellaneous Item Information: Buyer pays, I ship
Ill get some better pics after work tonight.
Good clean cheap power here. Most of these amps birthsheets were around 1k with 500 on the sub channel and 80wpc on the class ab side.
945
nutxo
nutxo
tacoma
BASS_WARRIOR
