Kicker?
Usually I will go to YouTube and search for a particular model i’m interested in and go on Crutchfield and check out reviews if they have it or some other websites
Not many like kicker around here
I like the Kicker CVR subs, the older silver 12's I had performed very well and handled their rated power no problem. I think for a more budget minded 2" coil sub, they are decent. Point is, I have no experience with the Q model, but I suspect in a quality box it would perform well, but box is key for most any applications. At first glance the Q looks decent, and Kicker generally makes solid products.
I think the point others were making is that, you can get more for your money buying other brands. It's your choice and if your heart is set on the CompQ, only you will be able to say how you like it after you use / hear it.
Ok fair enough I'll see what the opinions are. 1 compQ 15 is 429 dollars it does it can handle 1100rms. Looking for dual 2ohm. Everybody fire away
I Love JL I have a W7 and I know it was pricey but it’s what I loved. It’s all up to you and what u want like I said if you want loud the Q is nice but it will be discontinued so watch the warranty.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
873
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
Battery expert 2023
CarAudio.com Recruit
Battery expert 2023
Antarctica
shredder2
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
