SOLD Kinetik HC 2400 | Orion MBR 70 | TC db 500 10" | Diamond HEX S6.0m
nvme
Sold the car and now some of the items from it and the closet
Kinetik HC 2400 $190.00 - Was originally purchased to run a 3000 watt amp but that never worked out and only ran a 1200w planet audio.. Will include battery box that was made to hold it in place in my trunk if wanted.
Orion MBR 70 - $70.00 - Was going to install this along with the amp/battery but since I didn't get the amp I never installed it - I bought this used, the previous owner upgraded the connections to accept 2AWG wiring compared to 4.
Diamond HEX S6.0m mid range - $70 pair - I purchased these used but never got to install them
TC Sounds db500 10" - $65ea - I have 4 of these, they were powered by a Planet 1250, they are rated at 400rms 800 peak. All in mint condition, no scuffs or dust cap issues.
All prices do not include shipping - The battery will about $30-40 and the subs will be around $20. you can guess on the rest - Paypal or money order.
sorry for the late reply, I was depending on the email notifications to alert me of any posts.
I tried to measure today with a cheap voltage meter and it destroyed it when checking DC voltage, almost like the volt meter shorted out. I'll try and get a fluke from work and check it. When it was in my car I always had about 11.6 volts with the stereo on if that is any help..
prices are in the initial post - $65 and $20 for shipping each- if you buy all 4 then i'll discount it by $10 per sub
I'm firm on pricing since these have very little use and i'm not in a hurry to sell
Ok, i will go on this option. Thanks a lot bro for the help, i really appreciate again, Cheers
9
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
Ive seen so many amps done this way over the years. Especially ones that had the Molex plugs and a couple others
9
I have created a post with all related information regarding the build under this link: https://www.caraudio.com/threads/2000-camry-build.614208/
50
4K
Yes, they do. As for the Taramps remote control, it is for use with the EQ they sell, not as a remote bass knob. They are not very sophisticated...
24
4K
nvme
nvme
Medford,OR
revrider1
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
