Knu 4ga Amp install kit, Navone LOC N-RHL2
  • 2
duece212
Buddy Christ!
11,607
Colorado
Knu 4ga AMP Install kit w/ 120a fuse - SOLD
Navone Engineering N-RHL2 LOC w/ amp turn on circuit - Products
Knu 4ga AMP Install kit -BNIB
* 18 Feet 4 Gauge Blue Kolossus Fleks Power Wire
* 3 Feet 4 Gauge Black Kolossus Fleks Ground Wire
* One Waterproof Mini-ANL Fuse Holder with 120A Fuse
* One 5 Meter eKo Kable Blue OFC RCA Cable with Built in Turn On lead
* 20 Feet BLUE Klear Kable OFC 12 Gauge Speaker Wire
* 2 Gold Plated 4 Gauge Ring Terminals, 2 Gold Plated 4 Gauge Spade Terminals
* Split Loom and wire tie
Navone LOC N-RHL2 - Brand new in package:
2 Channel, 50 Watt per channel , Line Output Converter that will perfectly interface any OEM automotive system to an aftermarket power amplifier, equalizer, electronic crossover, etc. The N-RHL2 uses our "Industry Leading" NE-7V LOC circuitry, and adds the benefits of our N-902 Auto-Trigger circuitry� all in one convenient package. The PINK wire from the N-RHL2 connects to the Remote / Trigger wire of your aftermarket power amplifier so that it will turn on and turn off with the audio system. Let's say that you wanted to add bass to a factory system. Just tap into the car's factory speaker wires with the N-RHL2, and let the PINK wire control your sub woofer's power amplifier. Instructions included.
Knu amp install kit - SOLD
Navone LOC -$25 shipped in lower 48
Buy both, $60 shipped in lower 48
Have tons of feedback here, search the feedback forum for refs
wiring kit
loc
sale010.jpg%20%20
178
400
  • Locked
707
Amp
512
duece212
Buddy Christ!
duece212
Colorado
connersdad19
