L shaped Box
  • 2
snebweb512
16
Wi
hey ill be having a box built soon for 2 tempest 15s and i was wondering if this kinda box would work. My dimensions are 34W x 28D x 12H and then on the end towards the trunk it will have a 6H x 18W x 34 L addition so theres enough height to mount the subs. i figured out the 2 pieces seperatly and got 8.73 cubes. is this right or will it work and does it make sense. And does this sound like enough space for 2 tempests? thanks
Yes sir sounds like it will work as long as the two sections are sealed together well. And it should be enough room for two tempest. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i see, good to know At least. that means i could squeeze out more air volume indeed. bit of a crude design but so far was thinking of roughly...
Start by laying the larger bottom panel in an open space, then slowly “dry” assemble it by laying the pieces where they go like a puzzle. It...
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
187
The it to a custom air brush guy and tell him what you want. You can always stain, plexiglass windows, and put led lights inside the box. Search...
6
537
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
840
snebweb512
snebweb512
Wi
ramos
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
