Lci2 or Kicker Kxa??
  • 2
I am going to be doing an install on my 2019 ram 1500 limited. I ordered the kicker kxa 1200 amp wich pulls signal from stock speaker wires and uses is as remote and rca (essentially a loc) but my question is would I be better off using the lci2 or the amp? Why or why not
Assuming the amp inputs can indeed take the speaker level okay, I say try the amplifier first and see how it works out, no sense in buying extra stuff if the amp is supposedly capable. Otherwise the AudioControl converter would probably work fine for the application if needed, but I'd try just the amp first to keep it simple.
That is what I was thinking, I just didn't know if anyone had used it before maybe it didn't work like advertised but hopefully it does. Thanks for thebreply
Years ago there would have probably been guys with hands on experience to share, but seems the forums are pretty dead these days so it might be a slim chance someone running that specific amp like that on here; unfortunately you might be the one that has to test it out and see if it works properly. You’d think a modern amp should run high level input no problem though.
I have noticed forums are pretty dead now a days, once I test it out I will let you know how it goes
Two ways to go about it. First, the easy way- Next, the budget but more involved way- On the second one, you buy the harness to install an...
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
671
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
Chalo_209
Chalo_209
Kingsport tn
Chalo_209
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
