LED wiring
its not something i recommend but you can gust hook pos and neg to speaker pos and neg. or you can buy a light control box but cheapest way is to just put the pos under the pos on the amp and neg on neg side of amp
but again i dont recommend it
yeah i was told when i got it not to hook the lights up to the amp. the box does have the plus and minus hookup for the lights i was just unsure of how to wire them the proper way and how to get them to pulse with the bass
its not something i recommend but you can gust hook pos and neg to speaker pos and neg. or you can buy a light control box but cheapest way is to just put the pos under the pos on the amp and neg on neg side of amp but again i dont recommend it
lmao! really? do you know what a car amplifier does? its in the name.... also totally dif type of current comes from the output section of an amp.
op dont do this, would be dumb anyways.
yah, you might as well plug them into a house recepticle if you do that. at least you won't fry the house outlet if the leds short the wires before blowing. really, if you want it to pulse, you need a controller, or swap them out for leds with sound response circuits built in. either way, they need to be on 12v dc....
see i got the box from a friend and he said to me that it has a switch where you can either keep them on constant or have them pulse the lights are built in and all but i dont know if he was right on the switch atleast i have yet to find one
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
189
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
598
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
8
636
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
646
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
555
noonbns
noonbns
ickesburg, pa
akheathen
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
