level 5 18s box help
  • 2
longdan13
Im planning to build a box for 2 level5 18s m1. Im useing 1 inch mdf with double baffle.Are these deminsions good.as far as port deminsions and size.i only listen to rap. Its going in a 94 s10 blazer
Unit of measurement: Imperial
Wood Thickness - 1 inches
Displacements - .52 cubic feet
Frequency - 31.94 hz
Box Length - 48 inches
Box Width - 37 inches
Box Height - 22 inches
Port Length - 20 inches
Port Width - 30 inches
Port Height - 6 inches
Gross Volume(Feet) - 18.63 ft³
Gross Volume(Litres) - 527.54 L
Net Volume(Feet) - 15.3 ft³
Net Volume(Litres) - 433.04 L
Port Displacement(Feet) - 2.81 ft³
Port Displacement(Litres) - 79.57 L
Port Area - 180.0 in²
Port Area(Metric) - 1161.29 cm²
Port Area Per Foot - 11.76in²
Port Area Per Litre - 75.87cm²
the port part of your measurements confuse me. i see the 11.76in per cube, and i wonder how you got that? 180sqinch^3 / 18.63 is 9.66 per cube. But doing 180 / 15.3 is 11.76. I thought that you figure this by the total gross volume of the enclosure. it again i have been confused by this for a while but didnt understand which way was correct.
I used a box tune calculator to get those numbers.i just kept playing with the deminsions to get the hertz around 30-32 and the inches^2. Of the port Around 180- 200.
Factory. 2021 Chevy Silverado custom trailboss
9
859
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
5
882
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
745
I came across those too. Seen all the drivers out on the alibaba sight for sure. Wonder who is making them for PPI? Looked long and hard at those...
28
longdan13
longdan13
arlington,tx
longdan13
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
