lights above my head rattling
  • 6
I'm in the middle of trying to fix the same problem I guess as your having my roof is flexing and as it goes back and forth it's smacking the dome light, mine sounds like a blown woofer at full tilt until you reach up and press hard on the dome light, I'm think about pulling the light out and spraying in expanding foam to create a solid structure with no void between the headliner and roof panel.
I was having that problem in my Grand Cherokee. All 4 of my overhead lenses were rattling. They were rattling so bad that the rear lights broke off the bracket and kept blowing the Int. Light fuse. I pulled the lenses off and took the bulbs out. Interior lights are over-rated //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Ditto in 97 jeep Grand. Broke out all lights and the console in the roof fell out. Expanding foam may help.
Came across these. Rechargable, so you don't need to wire anything in and have a OEM look. I don't know if they're reliable or anything, I just...
5
750
Turns out that the big 3 cables connected the ground had some rust on the surface, brushed them with a wire brush and now there is no dimming...
8
Turn up the radio until you hear the cracking then dial it down like 2 notches Set the gain on your amp to that point or get an aftermarket head...
6
6
117
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
531
BoomBoxStereo
@woofergram
BoomBoxStereo
Long Island, NY
ThatChevyGuy
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
