DBFan 10+ year member
TEAM CRUNK
my lights are dimming even with out my bass on (just mids & highs), what could be wrong? i have a stock 110A alt, big 3 done and a stock batt. anyone have any idea????
suzuki forza, im running about 1400 wrms from my front stage.lights are dimming because of your electrical. its either your alt or battery or you just REALLY need a bigger alt. it helps a lot if you post what you are using and dont write off peoples advice.
we need to know your car, amps, ohm load, total power, what volume they dim at, size of wire.
edit- with the system off, the car is running the way it was designed to. if you add a bigger draw then the electrical isnt made to keep up with it.
