nu2spl 10+ year member
hey im looking for an LMS thread adapter plate,i also need to know if it has the standard 6 bolt pattern or not.
They are more commonly referred to as QCA rings. Are you looking for the 3" or 4" version?hey im looking for an LMS thread adapter plate,i also need to know if it has the standard 6 bolt pattern or not.
well im not sure,lol.i should find out which one the basket has,if i can find them cheap enough,i might just get both of them then i know ill have the right one.They are more commonly referred to as QCA rings. Are you looking for the 3" or 4" version?
The 3" is a 4 bolt pattern and IIRC the 4" is a 6 bolt.
The size refers to the size coil you have not just the basket.well im not sure,lol.i should find out which one the basket has,if i can find them cheap enough,i might just get both of them then i know ill have the right one.
its a 4" so i need the 4" QCA ring,do you have it? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifThe size refers to the size coil you have not just the basket.
Also these are not easy to find so finding one of each size may take some time.
