SOLD LNIB A3000DB - 225 shipped
BassAddictJ
FL
Best 2kw @ 1ohm budget amp around. Amp is 100% working and about 9/10 on the cosmetics. No major scratches, still very clean looking. Comes with box, manual, remote, strapping cable.....Everything that a bnib a3000db would come with. Typically these go for around 225-250 shipped for amp only and ussually beat up looking. I want 200+ ship for this LNIB one, so lets say 225 shipped. Pics upon request for serious inqueries
rated 2300w rms @ 1 ohm. Unless you have bad imp rise you'll see 2kw off 12v 1 ohm nominal. they're pretty efficient too. Even at 12v it takes a bit of abuse to get it hot. These take the abuse much better than several other similar rated "quality" brand name amps ive played with. I've ran these @ 14v full tilt for over an hour crammed between the box and the back seat with little to no ventillation and it was barely warm.
for those of you who have played with these you can vouche, for 200ish bucks it's a stout 2kw.
i just bought one on flebay for 170 shipped used. ive got it set to 1600wrms at 2 ohms on a set or re se's and let me tell you that **** slams. this is a seal for 225 and op is correct they seam to never get hot. i can bump for 1hour and put my hand on the amp like its nothing
same amp as the PA
thats the rateing at 13 volts imagine what you can get out of it at 14 volts
Ive seen so many amps done this way over the years. Especially ones that had the Molex plugs and a couple others
9
BassAddictJ
BassAddictJ
FL
BassAddictJ
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
