LOC / Mono Block amp and Sub question
  • 2
pghram1500
Hey all, I have a 2017 Ram 1500 Rebel with the non alpine stock system, so I do not currently have a sub installed. I am looking to install a single 12" sub with a mono block amp. I have been reading so much that I am confused on two parts if someone could please help me out. First for my LOC, do I need just a normal decent brand LOC. I keep reading about the Audio control LC2i. Sounds like a great unit but do I really need that for just a mono amp going to a single sub. This is an expensive truck so I do not want any feedback or noise on the line. Secondly can I hook into my rear door speakers with the LOC instead of behind the head unit. Seems to be people on both side of the fence on this. Finally if I do hook into the rear door speakers, do I have to do both or can I just hook into one? Second part of that question if I do just hook into one on the LOC do I tie the right and left together and hook to the one door speaker or just cap off whatever side I do not use. Thanks for any replies. Really want to get this going but need some assistance first.
498
Yeah tapping off the 4 gauge is typically fine. However, you need to fuse the smaller wire right by the 4 gauge at 1 amp (or whatever the small...
906
Thanks for the link to this video, I've seen this one before but it's not for component speakers which is what I'm going to install and the part...
831
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
pghram1500
pghram1500
Pittsburgh, PA
LosIsATool
