Loc questions
  • 2
JuiceTin
CarAudio.com Recruit
46
Texas
I have a friend who is trying to just add some subs and he does not have sub outputs on this stock head unit. So wondering how we get sub outputs using an l o c. Wondering if we would just take one of the speaker cables run it to the Loc and that would split it not really sure though.
I’ve used this one from Kicker a few times for installs. Just ground the black wire, connect the 4 speaker wires to existing wires connected to your car speakers. I actually installed the loc in the trunk and used the rear speakers. This particular loc does not use a remote wire. It comes on with signal from speakers. Hope that makes sense
Yeah tapping off the 4 gauge is typically fine. However, you need to fuse the smaller wire right by the 4 gauge at 1 amp (or whatever the small...
794
Thanks for the link to this video, I've seen this one before but it's not for component speakers which is what I'm going to install and the part...
4
630
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
11
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
unfortunately no empties but a couple promising choices, out of town right now have to this weekend 1) Car Radio Switch, Climate Control System...
5
JuiceTin
JuiceTin
Texas
Ridinhi
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
