LOC vs. New deck, under $130.
  • 3
Mr.meyhem
I have an 09 honda civic lx. So i don't want to be cutting it up. But i was thinking bout mounting a deck where the cup holders r or in the glove box. The LOC would prbly cost less and be easier to install, but i've heard they don't give you the best sound quality. Any tips on which to go with or on good LOC's?
Thanks.
I have messed with only 3 loc's so far and nothing ever went right and I hated every minute of it. Spend the extra $ and get a deck with built in crossovers and filters as well as a stronger and cleaner output signal. Its hard (at least for me) to set the gain with an loc. The speakers will still get a full range signal and will produce a muddy sound when trying to hit the low bass notes but the bass will be louder because of the addition of the sub. A new headunit will have a low pass filter which stops frequencies below a certain frequency to the sub. This is an absolute must imo.
6
171
Yeah tapping off the 4 gauge is typically fine. However, you need to fuse the smaller wire right by the 4 gauge at 1 amp (or whatever the small...
838
Thanks for the link to this video, I've seen this one before but it's not for component speakers which is what I'm going to install and the part...
4
717
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
11
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
Mr.meyhem
Mr.meyhem
Cold as F***, MN
Wingsfreak9
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
