Looking for help on a setup that fits ME! Help is appreciated!
ok lets start off with a nice deck now it is going to end up being kinda expensive in such a new vehicle as harnesses for them are not so cheap around 100 for just a harness for the deck then around another 50 for the steering wheel control integration module.is there any specific features you need from the deck (ipod controls, usb,memory) or what ever?Then lets move to door speakers your buddy could probably beat my prices for you on a set of cl-61i comps for the front doors and a set of cl-6ex coaxils for the rear. now for the front i would definitely get a nice 150x2@4 ohm amp for the comps but just run the coaxils in the rear off the deck for the passengers..Then a nice 12" idq or fi q in the rear and a decent class monoblock sundown or aq for the sub and for your listening preference i highly recommend a sealed box for the sub to get a quick and punchy response to those kick drums..
Really good feedback, but like I said... I **** with acronyms.... what are idq and fi q??
And how do I connect TWO amps together? Or do they both go into my head unit? And what amp do you recommend for that wattage and ohms?
EDIT: And whats the difference between sealed and ported sub enclosures and why is sealed the way I want to go for my preference?
acronyms:
idq = Image Dynamics IDQ sub: http://www.woofersetc.com/p2034/IDQ12V2D2--Image-Dynamics-12"-IDQ-Dual-2-Ohm-Subwoofer.htm
fi q = just what it says, Fi Q: https://ssl.perfora.net/www.ficaraudio.com/sess/utn;jsessionid=154acab27a97ca8/shopdata/0050_Speakers/0030_Q/product_overview.shopscript
dc = DC Audio aka DC Sound Lab: http://www.dcsoundlab.com/
"connect TWO amps together": I'll assume that you want to know how to run 2 or more amplifiers in a vehicle. It's called a distribution block. Do a google search for more information.
Sealed vs ported subwoofer enclosures: Both methods have their pros and cons. You honestly need to do some research before you buy anything, man. At least visit a shop or two and do some comparative listening...
a sealed box will have a tighter and quicker response especially on rock or metal music a ported box will be a little slower and not quite as tight sounding..and as far as hooking up multiple amps you are just going to need to get someone local with good knowledge to help you out that would be a ton of typing to help you fully understand..of course sundown audio has a new sa-12 woofer out that sounds real good on music also..
Hey, I have golf 2019. I have audison voce and want another speakers in front, and the Audison move to the back I have thought about those- Focal...
The amps are not fused themselves. I am considering using smaller gauge wire for the 200 and 300 watt amps (I believe they only recommend 12 awg...
I combine the fuse ratings of both amps and use that at the battery with the appropriate size wire and if an amp doesn have onboard fuses I will...
5
Well lets say I was running the tablet and 3 amps, would I use something more along the lines of a line output converter so that I would be able...
12
I'm in the same boat and have a few posts on several forums so this is NOT advice but just sharing what's going through my mind and we can help...
10
4K
snowdude1026
snowdude1026
Los Angeles, CA
dbeez
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
